Pipe Size and Type Rec for pump install and water line
jjmc95
Richmond VA
New well 175 ft deep, 75ft static water level, 30 gpm recharge rate. Water will be pumped to 80 gallon pressure tank about 20 feet from well head with 40/60 psi pressure switch and then on another 30 or so feet to my house.
Temporarily dropping this Vevor Pump https://www.vevor.com/deep-well-pum...AdYzBunx54wpsYDWsaoP8UzcJo-HPJmNWdXWJO9OOfn_o
This will run for 2-6 months, during which time I will test my water for grit and set up my solar situation. My plan is to put in a Grundfod 11-sqf-2 Helical rotor pump in the spring, assuming the grit level ain't too bad.
My plan is to use black 1 1/4" poly pipe down into the well and then from the well to the house. This means I need something like 225-250ft of pipe.
My questions are:
1. What are the pros and cons to poly vs. PVC or other options, particularly as underground water lines?
2. What psi rating and other specs should I shoot for with the poly?
3. Any tips on finding longer lengths of poly pipe? seems they often come in 100ft lengths. Or should I just use 100ft lengths and have to make a connection in my well? Is that pretty normal?
4. Would it be a bad idea to run 1 inch pipe instead of 1 1/4 inch? It seems more widely available in longer lengths.
GReynolds929
WA
Should be able to get 300' roll from a supply house. Iconix and Ferguson waterworks carry it in my area. I would use 200 psi at minimum.
RetiredInGueydan
Active Member
SW Louisiana
My questions are:
The temporary pump chosen doesn't build enough head to be used in that application.
Polyethelene will be more forgiving of thermal expansion and contraction.
Do not pull the pipe tight, but snake it in the trench.
RetiredInGueydan
Active Member
SW Louisiana
FredG
Idaho
Since those pumps are 115v, you are going to have to run bigger wire to the pump, making cheap, expensive in the long run. Install one properly sized pump, and be done with it.
I am skeptical of the specs. Imagine a 115 V 2HP motor.
FredG
Idaho
It’s possible, just not for $150. Using a cheap chinese pump in a cistern is probably worth the risk, since it’s easy to replace. I wouldn’t want to be the fool that has to pull it up out of the well often to replace it. Pumps rarely go out when it’s 75 and sunny.
RetiredInGueydan
Active Member
SW Louisiana
Those pumps are rated with Chinese math having high HP per amp draw and will work with smaller than normal wire sizes. This is a temporary pump used to clean well for 2-6 months and will be cannon fodder afterwards.
FredG
Idaho
In my experience, “temporary” is code for I’m too cheap to pay for a good pump. Nobody in their right mind is going through the work of pulling, and replacing a pump just because, if it still functions.
RetiredInGueydan
Active Member
SW Louisiana
Take some time and read before you spread your wisdom.
FredG
Idaho
I read that, and stand by my statement. Is doing the job twice the new wisdom? Wouldn’t surprise me.
Pulling a pump hanging on 1-inch poly hanging from a pitless may not be as hard for jjmc95 as you think. He may want to fabricate a giant pulley made from an old tractor drive wheel etc. Another alternative is to use two smaller wheels as pulleys, rather than making a 90 degree turn on one pulley.
However two strong people may be able to lift things hand over hand, especially if there is something to hold the pipe to rest. https://deanbennettsupply.com/INSTALLATION-TOOLS?parentCatID=11505&subCatID=11759 Maybe one strong puller, and another person to assist with the clamp etc.
It is also possible to use a pump puller, such as up-z-dazy OR "pul-a-pump" OR PumpTrax OR "Easy Riser". I think one might be available at a rental place, but that would be rare. https://www.rentalsunlimited.com/rental-equipment/well-pump-puller-electric/ has a listing but not a location.
That contemplated Grundfos 11-sqf-2 is very expensive.
jjmc95
Richmond VA
Thanks all!
Yes I’m not thrilled about having to pull this pump so soon after putting it in but I decided it was worth not pulling the grundfos after it broke from too much grit . Grit is an issue for the helical rotor pumps which I really want to use for my solar set up given their performance in low sunlight conditions . Indeed those grundfos are expensive !! 30x more expensive lol
The wire I planned to run for grundfos is same
Two wire 10 gauge as I plan to run for the Chinese pump .
