Hi all,
Recently had a hot water tank replaced with a Navien240. Immediately after this, we began hearing dripping noises between the 1st and 2nd floor of the house -- nowhere near where the Navien was installed. It's not actually dripping -- there's no visible water damage. We thought it was thermal expansion of the pipes (CPVC), and two plumbers have been out and agreed.
The installer insists that this thermal expansion is not related to the Navien 240, and calls it a coincidence that the noise started when the tankless system was installed (literally the same day). While that's possible, it's a remarkable coincidence.
Our previous hot water tank had an external recirc pump that was removed to use the Navien internal pump. When I checked last week though, the Navien DIP switches and two-way valve were set for external recirculation. I've changed both to the internal settings, but the noise has persisted. Just today, I turned the recirculation completely off and will wait to see if there is a change over the next day or two.
Any ideas here for what if anything about installing a new tankless system would cause thermal expansion noises to start in our pipes?
