DIYorBust
Active Member
Hi Folks,
I'm running some under slab waste pipes to serve fixtures in a basement including washing machine, and half bath. The plan is to use sch 40 no hub cast iron. Would it be worth upgrading to stainless steel? I also speculate whether PVC would work better, but I believe it may not be code compliant in this particular situation, and I wouldn't want to drain a 180 degree water heater into it, which is also a possibility. Thanks for the advice!
Edit: I should add it will be very expensive and difficult to access the pipe after the project is complete, so probably if it fails it will have to be pumped up and rerouted. That's why I'd consider some extra expense for better pipe.
DIY
DIY
