Zimm0who0net
I've got a 1-1/4" PEX line coming from my main house to a guest house (it's after the main shutoff). It obviously needs to surface through the slab and into the guest house. My drafter tells me to surface outside the guest house with copper, go through a shutoff valve, and then through the wall into the guest house where I can transition back to PEX.
My question #1: If PEX can run underground, above-ground, and through a slab (protected), why do I need copper at all? Can't I just surface inside the structure with PEX and go from there?
Question #2: The line running from the main house to the guest house has a specific shutoff for that length already. Do I need an additional shutoff AT the guest house? If so, is there any reason I wouldn't put that shutoff inside the structure? (here in southern AZ almost every water shutoff I've seen has been outside the structure, but that seems silly to me given that we DO occasionally have freezes)
