I have a couple of questions regarding my new PEX plumbing system.
I recently installed a 24 port Manablok with 3/8" supply lines (Plumbing supply store recommendation) to each of my fixtures. The home is only 1800 sq. ft. and I am supplying 2 full baths, kitchen, and a laundry room. I have 3/4" supply coming into the house.
My questions:
1) I am concerned about supplying the kitchen sink and dishwasher (hot) with a 3/8" supply line. The distance from the Manablok to the kitchen sink is about 23'. Should I "T" off the 3/8" to the dishwasher or run a dedicated line to the dishwasher? I'd hate to have low water pressure while the dishwasher is running.
2) The Manablok serves as the shut-off for each fixture. However, after doing some research, I've learned that inspectors(code) require certain fixtures have shut-offs at the fixture (toilets for example). I also plan to have a shut off under the sink for the dishwasher. Will the Manablok individual line shut-offs suffice for all of the other fixtures as far as an inspector would be concerned?
3) I have 3/8" hot/cold running to the showers. I stubbed out the wall with copper from the shower valve. From the valve to the drop "T" (shower head) I only ran 3/8". Is this going to be sufficient? I guess I'd better pressure test before I tile in the bathroom wall.
Thanks.
My questions:
Thanks.
