That large (1-5/16") PEX looks like a sleeve for burial and passing through the concrete slab. The smaller PEX tube inside is probably your water supply line.
Actually the big PEX tube is the supply. I just cut a couple inches off both lines to take to the big box store and see if I could make a connection between the two, when I took the picture I just had that 1/2" sitting inside of the larger PEX
1/2" pex is pretty small, even for a cabin, as the main supply line.
It just doesn't flow that much volume. If someone is showering and someone else starts to use some other water, both may notice. But, if the well is a low producer, and you have a big enough storage tank, it might be more than adequate...would need to know the whole setup.
How far away is the pumphouse and how many gpm does it produce?
As I mentioned, the supply line is the larger 1-1/4" PEX. However you bring up an interesting thought with talking about the well, pressure tank and pump. There are two othere houses, total of 3, on our 1 well. There has been two on the well for some time, but we just resently added this 3rd cabin. I'm wondering what the effect might be on the pump, supply and overall system. Honestly, I don't know for sure the output of the pump. The pressure tank I'd say is about 2.5' tall and around 2' diameter? Both more than likely origonally installed in the mid 90's. Out actual well is pretty shallow, I think around 25', and as far as I know has never had any issues with running low.
Is there any good why to test the output of the pump? Would you sugest upgrading pump, tank based on test results, age or the addition of the cabin?
For what it's worth, well is located on edge of propery. From there a mian line runs to our well house about 75' away. In the well house we have the pressure tank, then a main line that splits in 2. One line runs directly to one of the houses, 200' away. The other line splits again and runs to each of the other houses, 1 about 100' away the other about 200' away. When we added this 3rd cabin I was thinking of upgrading the whole system, but we have thoughts of adding an addtional cabin or 2 and though at that point we would upgrade if needed.
