I need some advice on sizing pex pipe on a dedicated hot water loop I am installing in my home. It is a 2,400 SF single story ranch home. The basement is unfinished and I am running the lines in the basement ceiling before I finish the area. A sketch of my initial plan is included.
Also, I am buying a new water heater for this system since my current model is over 15 years old. I plan to install a 40 gallon natural gas tank heater with atmospheric venting. I am also open to feedback and suggestions on the water heater. I am wondering about a larger tank size and maybe power vented. There are only two adults living in the house for the foreseeable future. The purpose of power venting would be for gas efficiency and to eliminate the last atmospheric vent in the house.
- Distance from water heater to farthest fixture is approximately 65’
- Piping will be pex A with cinch fittings
- I have initially planned to run 1”pex pipe until I reach the last fixture, then ¾” pex pipe back to the water heater
- Pump is Grundfos UP15-10
- Water will reenter the heater through a T in the cold water inlet pipe
