Gary in NJ
I've completed a hot water base board project in a converted attic. I ran about 250' of PEX and 7 registers. Before connecting this loop to my furnace I thought it would be prudent to pressure test the connections.
I decided to make my own tester with a brass 3/4 tee with a 150psi meter out the top, a 3/4 PEX barb on one end and a ball valve/quick disconnect air barb out the other end. All of the connections and the necessary bushing have teflon tape.
I decided to bench test my tester - and it leaks like crazy. All of the leaks are at the 3/4 brass tee. Should I be using sealant for this fitting or a galvanized tee? I placed the tee in the vice to REALLY torque down on the fittings, so it's possible that I distorted it. So, what should i use for PEX Test V2.0?
I am encouraged that my ring on the PEX barb and the ring at the plug don't leak.
