tamuguide
I moved into my first home this past May. During the home inspection it was discovered the pressure at the hose bibb was in the 100-110 psi range. A pressure reducing valve was installed prior to moving in, I checked the pressure this morning and it was reading closer to 60 psi. Now, within the last month 2 leaks have happened on the PEX water lines in the attic. Both have been on the Hot water lines. The most recent was 3/4" <100' from the hot water heater. The first was 1/2" less than 1' from a copper distribution manifold. I am curious if the high pressure could have caused damage to the lines, what I can do to determine if any other areas are compromised, and what I do to prevent these leaks from happening in the future? Thank you in advance for your response.
Edited to read Pressure Reducing Valve by Admin
10/12/2017
10/12/2017
