jemibu
Have you ever reached the end of a marathon and decided "hmm I'm not sure I like the way I ran, I want to try it again"? I am replacing the plumbing in my 1940's 1 1/2 story single family house in Minneapolis. Open system, fairly clean city water. Galvanized pipe run amok through the house. Months ago I designed and installed a PEX remote manifold system parallel to the original. The intent is to replace the final few feet of fixture lines over a weekend.
In retrospect I wonder if I've make poor decisions though. Not mistakes. Just dumb choices. So I've come here to get railroaded by those with more experience. Or, have the confidence instilled to wrap up the install on the current layout
Here's the first replacement
Mind you, I've already run these lines and have paid for and connected a lot of LF brass. But I'm not opposed to ripping out and starting over. Now's a good time to mention that I'm a sadist.
Layout version 1
Primary manifold
Example of one of five remote manifolds tucked between floor joists
New system not connected to city water supply yet
But in hindsight...
You'll notice I added a bathroom. Magic! Capped until the bathroom is actually added.
So... would starting from scratch give me such a better system that it's worth the effort to replace the replacement?
Layout version 1
Primary manifold
But in hindsight...
- The distances between sources and fixtures are short. But my runs and volumes are abnormally high. It's going to take a long time to get hot water. As mentioned before, I'm a sadist and am impatient to get scalding hot water.
- Maybe a dedicated recirc line from each manifold will help . But some remote manifolds be 'preferred' when the pump pushes hot water toward the primary manifold.
- I overlooked that silcocks don't need filtration
- Install looks fancy but why the hell do I need to shut off one zone at a time? That's a lot of brass fittings and potentials for leaks (*NOTE access panels will be put in the drywall to get at every manifold. No other connections are behind walls. I planned for leaky fittings even though I tightened the bejesus out of them)
- I discovered how much I really love gauges and valves
