Steve_A
I am installing a multiple head shower that could use up to 10gpm (not likely but could if everything is on). Currently fed by Navien 240 (may need to add another but that is for another day). I have 3/4" PEX B feeding 3/4 Copper risers then too 3/4" PEX B into the Kohler DTV+ 6 output valve. I'm concerned the PEX B fittings (I've kept them to a minimum but there's still 7 crimps) will cut my flow. I don't have access to PEX A tools.
Two Questions
1) should I replace all the PEX B with 1" now that I have it all open or is it not worth it? I figure it will cost me about $150 to replace all the hot lines that I've already run. The Cold to the hot water heater is all 3/4" PEX A and is fully accessible back to the main (which is larger than 3/4, haven't measured it).
2) Is there a problem leaving the cold run to the shower at 3/4"? I'd expect to use very little cold water on that line.
Two Questions
