PEX and Hot Water Heater
OldFart
North Carolina
OK, here's the problem. I'm getting ready to replace an existing lo-boy hot water heater that is under my kitchen counter. I live in a very small house that was built ten years ago. The HW heater was installed by the builder. I have read here that code requires 18 inches of copper to a HW heater. It is currently connected with PEX! There is also very little room to even use a flex copper pipe here. The entire house is plumbed with PEX. The pipe to the heater comes out of the wall, and is only about twenty inches long. So how am I expected to connect this, and be up to code?
Maybe add a couple of brass elbows if the overhead space is to limited. It's not clear from your photo if there is more space above.
With an electric water heater it might be okay to run PEX to it. Not so with gas.
Take good measurements, as water heaters have changed in size since yours was installed.
