Anything ridge can crack from ice.With the problem in Texas, i wonder would PEX-A be a better choice vs copper since PEX-A can expand when water is frozen. The other thing i wonder is, would PEX-A plastic fitting crack
I posted a link to a study on the survivability of PEX to freezing. Basically the PEX A can withstand several thousand freeze thaw cycles before failing... until the distance between fittings gets to 7" and below. Then theres no room for ice to expand and it builds up pressure in between plugs.. boom.
A glass milk bottle will handle freezing if the stopper can lift out. The ice can flow and extrude out of the top. I think that enough pex pipe near each side of the fitting would make EP (engineered plastic) survive too.No PEX fittings that I am aware of are truly freeze resistant. They must be made out of very rigid material in order to seal to the pipe. You freeze them, they explode. Pipe can handle freezing.
Next time you will have really cold weather, try putting a whisky bottle with water in it outside. Use no stopper. Bet the bottle does not break. Expect a cylinder of ice above the neck of the bottle.
For future, my guess is people will build to avoid freezing. That's important generally I think copper lives longer but freezing pipes is always bad so Choosing pipes that take cold better isn't answer its preventing them freezing that's crucial
