HomeFront
We are stumped in troubleshooting our Toto Soiree Sanigloss toilet and hope you might be able to advise how to proceed.
We replaced a prior toilet at the advice of our service plumber because it just wouldn't flush reliably despite multiple plumbing calls. Since installing this new toilet we have continued to have trouble. We have now camera'd the Toto Soiree to the street, hydro jetted the stack, as well as frequent plunging and snaking. This represents thousands of dollars invested in the toilet, yet the toilet is still not working well. It doesn't seem to be a whole hose issue since our cheap Gerber basement toilet has been working fine all of the time.
It seems like we may have several distinct problems with the Soiree, though perhaps the are interrelated.
1. Persistant incomplete flush - even just urine with no toilet paper doesn't go down the drain. This is almost always better on a second flush, often enough to get it down if you wait for tank to fill fully. It also gets a little better if you flush a whole bunch of times or plunger. On the first flush, the water just doesn't move very fast into the bowl.
2. Considerable staining of the toilet bowl from the very first months of use. The worst stains are mottled brown, in the narrow portion of the bowl at the bottom. We have used vinegar, water, borax and Seventh Generation toilet bowl cleaner with a scrub brush to try to remove, but haven't used pumice stone given the sanigloss care instructions.
3. Handle has to be held down to flush or flapper closes way too quickly. The plumber replaced the flapper with a new one because it was degrading, but this problem has persisted. Surely this is a simple issue and not related to the others?
4. There is a trickling sound several times an hour - sounds like the tank is refilling but there is no perceptible movement in either the tank or bowl, and the water level in tank doesn't seem to be dropping. The bowl level sometimes does seem to be dropping slightly. Someone had mentioned this is due to the plastic trap, but I don't quite understand the connection. This has been there literally from day one of installing the toilet, but the plumber said not to worry about it (and there's no water leaking to ceiling below as far as we can tell, also tank not leaking into the bowl (did dye test overnight).
5. There are lots of calcium deposits in tank, which surprised the plumber given the newness of the toilet. We have hard water in our town. Upon the plumber's recommendation, we have used vinegar overnight in tank and bowl. Then you can peel the calcium out of the tank at least..
Could items 1/2/5 be calcium blocking the line between tank and bowl? If so, how do we go about cleaning that out on a one-piece toilet??
What other solutions should we explore, or do we need to replace the toilet, again? This is particularly disappointing because we selected Toto and the Soiree because of the strong track record of cleanability and performance.
Thank you for your assistance!
