I have a Performa valve with a Pentair 740 controller. This is actually being uses as an iron filter. The problem I have is that it's not pulling any of the solution from the chemical tank. In fact when I put the valve in regeneration draw it actually pushes water out of the drain line instead of creating the vacuum and pulling solution into the tank.
I have taken the unit apart and cleaned it as best I can. Any solutions? I called my water tech the other day and he told me that the iron filter needs to be removed and cleaned. Any ideas on what he means by it? Cleaned in a special way?
