struman
Hi,
I have a Pentair PID-50 with a 3 phase 5hp Pentair P43B0050A3. Deep well ~1000ft
About four months ago, the PID died on its 4th anniversary - ground fault. New PID just started giving over current fault and slams off ~17-20psi seconds after restarting. However, the pump out feature works fine...and will run as long as we let it. Reset breakers, checked pressure sensor at tank, input voltage (240) and amperage readings (during pump out). Spoke with tech support and they said it's probably a bad PID...
Installed new PID this morning...same result - ugh...
If there's an issue with the motor, why would pump out work fine? Any other ideas?
thank you
Steve
thank you
Steve
