Pentair 64k Grain System - Not Using Salt?
Bannerman
Ontario, Canada
Let me in on the joke
Your photo is clearly showing the connection lines to and from the softener are connected together. While the softener will fill with water, the flow will bypass the softener so water to your home's fixtures will not be softened.
I thought that was the error you were referring to when you first posted the photo. Maybe you were referring to something else less obvious?
BBdude
Buffalo
You're right. I thought dittohead was pointing out the ball valve, not the loop. Makes sense now.
Bannerman
Ontario, Canada
Not sure what the plumber did, but this morning our hot water is full of salt.
I suspect he corrected the unintended bypass loop and then incorrectly reduced the Brine Draw setting and initiated a manual regeneration.
Not certain for your Erie brand control valve, but the Brine Draw and Slow Rinse cycles are typically combined into a single 'Brine Draw' or 'Brine' setting. The 'Brine Draw' setting will be most commonly 60-minutes, causing all of the brine to be transferred from the brine tank to the resin tank within~15-minutes, so the remaining ~45-minutes will cause slow rinse flow to push the brine through the resin bed and out to drain while at the same time rinsing the resin with fresh water.
When the Slow Rinse time is insufficient, some brine may continue to remain within the resin and will exit the softener into the home's plumbing once the softener has completed the regeneration cycle and the softener supplies water to the home's fixtures.
BBdude
Buffalo
Plumber just left. Seems the system is working fine now. Once the regeneration completed, salt issue was remediated. Valve still not working right or counting gallons used, so that's next piece to remediate.
Bannerman
Ontario, Canada
Almost all modern softener control valves will bypass the softener during regeneration so no brine can enter the home's plumbing if any water is drawn while regeneration is underway.
Perhaps no automatic bypass during regeneration is one of the problems that Ditttohead alluded to with that Erie valve and may have been one of the reasons why he advised to replace that control valve.
In reviewing this forum, most recommendations are to obtain either a Clack WS-1 or WS-1.25 control valve, or one of the various Fleck valve models that are currently offered.
BBdude
Buffalo
This is helpful, thank you. Sounds like the plumber thought replacing the control valve was outside what he was supposed to do. Owner is on vacation so will call him next week and suggest the above and see what he says. Certainly a control valve should still be covered on a product / install that's less than a year old.
