Pegasus shower handle removal
Raleigh, NC
I am in the process of replacing a cartridge in a single lever shower handle due to a slow drip from the shower head. I realized there is a cap on the front of the handle that allows access to a screw. I removed the screw but it does not seem like this allows for the handle to pull-off? I do not see any small screws or anything else holding the handle on.
The handle may just be stuck tightly to the stem, OR, you may have to unscrew the "dome" under the handle and the handle will remove with it. No way to tell for sure until you try pulling HARD on the handle.
Kenneth Lee
Rancho Palos Verdes
I am also in the process of replacing the cartridge and diverter for a 2006 Pegasus shower valve. I unscrewed the handle but cannot remove the stem which is stopping me from unscrewing the cone. I pulled hard on the stem but it won't budge, no set screw either. Any advice would be much appreciated! Thank you.
Kenneth Lee
Rancho Palos Verdes
Update: I had to saw the cartridge stem off before I can remove the cone and replace the cartridge. Then soaked the sawn off piece in calcium, lime remover solution, screwed a screw into the portion of the valve stem still stuck to the handle and tapped it out with a small hammer so that the handle can be reused.
gahndalph
Vermont
I have the same style faucet and the shower head diverter is leaking. I am looking at which cartridge is applicable.
