Pedestal sink plumbing
David E Leis
Florida
Replaced faucet and sink drain and had to shorten drain tube. Cannot shorten drain tube any farther and doesn’t quite lineup with p trap. Has a Small drip. Can I use a flexible ptrap here? Also sounds like I have a drip inside the wall after cutting drain tube. No drip inside wall before cutting tube.
Or any other ideas.
I think a 1 1/4 inch p trap might fit better youll need a 1 1/2 x 1 1/4 washer at the nut coming out the wall . sorry thats a common issue on ped lavs ptrap is too.long. another trick is to remove the regular trap adapter and use a spigot trap adapter so that nut is closer to wall
