Too Ambitious
Currently I have 2 bedrooms on my 2nd floor that open straight off the stairway. One of them is L-shaped. I am partitioning that bedroom into a smaller square bedroom. I will cut the original wall against the stairs to a half wall to create a semi-open flex space. (It will be used as a playroom at first, and eventually I may add laundry.)
The current HVAC setup: there are registers fed by 3.5x12 wall stacks under the windows. Someone came later and added 10x4 wall registers to the opposite wall against the knee wall attic. As it is, all 3 registers will be in the new (smaller) bedroom.
My question is whether I should move the 3rd register from the bedroom to the new flex space.
Floorplan is below. The red wall is the wall I added. The green wall is the original bedroom wall that will be cut to a half wall.
I will also be adding some sort of return air to the bedrooms (probably jump ducts / transfer ducts), too, since we're putting new doors on and don't want huge undercuts.
