Hey All!
First off just wanted to thank everybody for their contributions. I have learned more from this site than anywhere else, on the internet or in person.
I have recently acquired an older (1954 construction) home in need of a little updating, and I am hoping next weekend to update a few things in the bathroom.
The first order of business will be the toilet. The one in there is.... well past its prime for lack of a better word. I've replaced toilets before but I am a little concerned about this one due to the age of the home. From what I can tell most of the drain lines are cast iron. The toilet seems "normal" to me, similar size to any modern toilet, but it is strange that it flushes "forward" (eg the water goes toward you instead of away when flushing). Basically my question here is if you guys think I will run into anything unexpected (some weird fitting is my fear).
Next I will be putting in a new vanity/sink combo. The water connections are fine (house was repiped a few years ago) but the drain has me a little confused. Wishing I would have grabbed a picture, but basically the sink goes down and has a normal P-trap. Where the trap exits (horizontal), there is a 90, followed by another 90 (going horizontal again but the opposite way), which feeds into a waste tee. On the top side of the waste tee is a plug (presumably for cleanout) and the bottom goes down into the floor, where I can see the top of a rubber fitting with clamps (maybe to connect to the cast iron drain pipe?)
My question here is twofold. I will be buying a smaller vanity (since room is scarce as is), does anybody see an issue with extending the horizontal piece of the drain in order to compensate for the different location of the drain (diff size vanity = sink drain in diff location)? And, as I am thinking this arrangement is likely not code, will I run into any violations by replacing the vanity/sink? I am not thinking so but wanted to see what the pro's think.
Thanks in Advance!
Thanks in Advance!
