P-Trap leaks
BobN
New Hampshire
I'm a homeowner, not a pro. My 10-year old kitchen sink p-trap is leaking. A quick look showed a split plastic nut under the drain. This is the nut that compresses the drain metal pipe to the 1 1/2" vertical plastic pipe of the p-trap. Local hardware store sold me a new nut. I installed it and it seemed fine. I used silicone grease on the plastic threads, thinking that would make it easier to tighten and loosen in the future. To be safe, I only hand-tightened it. I didn't want to split the new nut.
Two days later, I noticed leaking from the other side of the p-trap. You can see the leak in this photo.
I used a long wrench to tighten that large nut another turn and the leak seemed to stop.
QUESTION: Does that large nut really need to be very tight? How do you know when it's enough vs too tight?
Thank you.
I would take the opportunity to bring your installation up to code and fix this problem at the same time. I would install an AAV and use a slip joint 1.5 inch P-trap. NH allows AAVs. There are many posts on implementing this. If you have trouble finding one, say so.
As to why you are leaking, I wonder if there is stress. A slip joint trap can relieve stress.
For now, what if you loosen the new nut, loosen and retighten the leaking nut, and then re-tighten the new nut, does that make the current leak go away?
RE: Cheater vents
Air Admittance Valves (AAVs) are generally allowed in New Hampshire, as the state plumbing and residential codes align with the International Plumbing Code (IPC) and International Residential Code (IRC). However, their use must always be pre-approved by your local code official on a case-by-case basis. [1, 2, 3]
RE: Cheater vents
