Hi guys,
Im installing a bathroom in the upstairs of a very very old farm house, the shower drain (2 inch PVC) is tight enough to a main support beam that it would end up very crooked if I dropped it low enough to do a normal p trap... there are 8 inches of room between the floor and the beam that I have to work with in which I can easily put a "normal" p trap. my question is if I put a sanitary tee right after the solvent weld ptrap outlet with the top of the tee being a 1 1/2 vent (through the ceiling to the vent stack) is it ok to then drop the other 8 inches to a long sweep elbow and then 2 feet at 1/2 drop to my drain pipe? the picture is very rough but you may get the idea from it
thanks to all that help!
