"Overflow" style pop-up drain on sink w/o overflow?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mc510, Mar 28, 2021.
  1. mc510
    mc510 Member
    Dec 18, 2009
    California
    My new cultured marble vanity top/sink does not have an overflow hole, but the pop-up drain that comes with my faucet does have holes for a sink overflow channel. I started off thinking that I'd need to discard the pop-up and buy a non-overflow type, but what if I use it? Some drain water will splash out the overflow holes and accumulate above the drain's lower (under-sink) seal. Sounds gross, but this same thing must happen when the pop-up is installed on a sink with an overflow channel, right?
  2. Tuttles Revenge
    Tuttles Revenge In the Trades
    Oct 15, 2014
    Some sinks that don't have overflows can't use a pop up assembly with an overflow because the depth from the inside of the sink to the bottom where the rubber and nut tighten isn't tall enough to cover the hole.. so basically there arent enough threads to get the nut that high. If the depth of the material is enough to seal with that pop up, then there is no downside to using what you have.
  4. mc510
    mc510 Member
    Dec 18, 2009
    California
    I think I understand what you're saying, and my sink is at least three inches thick at the bottom so the pop-up drain's overflow hole is definitely going to be sealed between the upper and lower surfaces of the sink. It still seems a little gross to be letting dirty water accumulate on top of the lower seal, but am I correct in picturing that this is what happens even if the same overflow-enabled drain is used with a sink that does have an overflow?
  5. Tuttles Revenge
    Oct 15, 2014
    Correct.. An overflow enabled sink will have an accumulation of grossness that sometimes needs cleaning out.. I've had one sink that had a foul odor from the overflow.. i believe a mix of vinegar and baking soda cured that.
  6. kreemoweet
    kreemoweet In the Trades
    Sep 7, 2009
    Seattle. WA
    Umm, I guess you haven't taken apart many lavatory sinks after they've been in use a few years? They are ALL gross, black and green slime
    just about everywhere. Take a look
    in the overflow channels too, if any, while you're at it. Not so easy to clean all that muck out, is it? People like to create images of white, immaculate, un-gross
    plumbing fixtures in their heads, but it is all a fantasy, at least with any ordinary level of cleaning effort.
Similar Threads: Overflow style
Plumbing Forum, Professional & DIY Advice Tub Drain & Overflow Styles Jan 22, 2014
Plumbing Forum, Professional & DIY Advice Emergency overflow on RV drain plumbing Jun 27, 2021
Plumbing Forum, Professional & DIY Advice Replace brass overflow tub and drain pipes Jun 20, 2021
Plumbing Forum, Professional & DIY Advice Foam overflowing from toilet and cost to solve the problem Apr 11, 2021
Plumbing Forum, Professional & DIY Advice Eljer tank no molded overflow Mar 20, 2021
