First time post - Recently added a new gas line separate from the line running all the appliances in the house. Tapped into the service side of the meter using a Tee. Out of the gas meter, we have 3/4 inch suppling both the appliances in the house on one line and also one line going directly to the fire pit. About 1.5 ft of 3/4 inch line from meter then 1 inch line for house appliances. That same 3/4 inch line from the meter uses a tee and it changes into a 1 1/4 inch line to the fire pit. about 1.5 ft before fire pit connection, line goes from 1 1/4 to 3/4 through a Key Valve and about 12 inches of 3/4 to fire pit ring.
Issue is when the key valve is turned on, slowly, we hear the gas flowing through the key valve and it gets louder the more we increase the gas. Until finally about 3/4 full throttle, the noise starts to dissipate some. Full open and the noise is almost gone. Wondering how to reduce that noise at the lower settings. I believe the noise simple the pressure of the gas flowing through the key valve. The more closed the valve is the more restricted the gas therefore making more noise. Should there be a regulator installed to reduce the gas psi but keep the volume of the gas the same? Is that possible.
Fire Pit ring is 300,000 BTU. Hopefully I have described this enough that you pros can help me get this figured out.
Thank you in advance for any help/suggestions.
