BDrivenByDemons
Let me start by saying my system is running great. I do my yearly maintenance and I'm super satisfied with my setup. Everything is the same as it's been since I posted this thread.
When I was doing maintenance a few weeks ago I was wondering if some of my cycles are too long? My 12x52 tank is approx 25.5 gallons and the 2cuft of media displace approx 15 gallons so I should have 10.5 gallons of water in there at any time. Can I just adjust my brine draw/slow rinse based on the flow of those which I know. I know my BD is .21GPM and my slow rinse is .275GPM. My 5.3 gallons of brine gets drawn out in about 25 minutes. To push another 10 gallons of rinse through @ .275GPM would be another 36 minutes. That's a grand total of 63 minutes. Follow that up with a rapid rinse @ 3.5GPM for 4 or 5 minutes and I should be good, no? My current BD is 101 minutes. Too long if my thinking is right. Can I verify the BD/SR is long enough by tasting the drain water to see if it's still salty?
Obviously I'm getting a little OCD here but if it saves water why not?
***Solution - the bubbles from the air check in the brine tank not closing completely were agitating my resin. When the pros here say the resin can not be disturbed during brining on an upflow it shows they know their stuff. I got 900 gallons of soft water once I fixed that problem. 48k capacity/900 gal = 53.3 grains hardness. When you multiply my actual 42 grains times 1.3 in the high hardness compensation chart you get 54. Right on the money. Hopefully this solution helps someone in the future...***
The details...
Fleck 5810SXT with upflow piston verified
#00 violet injector...
The details...
- BDrivenByDemons
- Forum: Water Softener Forum, Questions and Answers
