Opinions of Amtrol Boilermate
JohnCT
Still learning..slowly
Northeast
I'm going to add an indirect to my boiler's DHW coil in the spring, and want to check some options. Hookup ease is one consideration but the biggest is durability. I know it's tough to weed through internet chaff but I've seen whispers of the current generation of Boilermate not being as long-lived as the ones installed 20 - 30 years ago. Is there truth to this?
Thanks.
John
Fitter30
Peace valley missouri
This company has been around for a very long time. Biggest problem is lack of maintenance running cleaner through the heat exchanger. Water heater is always out of sight out of mind. Going to need a control to prioritize dhw.
Taylorjm
Active Member
Saginaw, Michigan
I have one that's about 10 years old. No issues so far. The reason I like it is just another zone on the boiler, no exhaust vent, the tank is lined so water isn't sitting in a steel tank and rusting out and because we are on a well, many people with traditional hot water heaters have issues with the anode rod causing the water to smell bad.
JohnCT
Northeast
My control does have those features.
How are those cleaned out?
John
PeterDux
Duxbury MA
Maybe mine is one of the good ones. 26 years old and working perfectly. I replaced my boiler two years ago but left the Boilermate alone.
Taylorjm
Active Member
Saginaw, Michigan
Wow, I never knew you were supposed to clean them out. Wouldn't it matter if your water is hard or soft? I can imagine that hard water would build up more scale verses softened water. We use a water softener so I know our water has near zero hardness and I test it to make sure. I may have to clean mine out and see. I already have a ball valve boiler drain always connected to a hose to the nearby sump pump to drain the tank every year since it's a vacation home. If I have to remove the t&p valve at the top to do it, then I'd put a tee and ball valve at the top so I don't have to remove the valve every time. Instead just drain everything, open the ball valve and funnel in the cleaner.
Taylorjm
Active Member
Saginaw, Michigan
This video shows coils removed from a home after 15 years using filtered, soft water and little to no scale build up. So it seems that the need to clean the units really depends on your water quality.
