Only need calcite in my system now with new well, tube sticks when adding calcite
Discussion in 'Water Softener Forum, Questions and Answers' started by Lizzard2, Feb 7, 2019.
  1. Lizzard2
    Lizzard2 New Member
    Feb 7, 2019
    virginia
    I have a CSI system. I have a reg. 2007 10"x 54" Enpress 1054 tank that is about 1/2 full of media. My well has tested zero for iron since 2007, with my new well. My PH has been about 6.4 at the pressure tank since 2007. The problem I have is every time I try to add a 50 lbs bag of calcite the tube raises up about an inch. I cut an inch off one time, I emptied the media one time.
    Should I get a csi dome hole tank for $200.00? Or do they make a cheaper after maket one? Has a 2-1/2" opening.
    Will I need to buy 20 lbs of gravel, for just calcite in a dome hole tank? There is no gravel in my current tank. I removed my aerator tank from the system about 6 months ago, I don't need it now right?
    Thanks
    Mike
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  4. Lizzard2
    Lizzard2 New Member
    Feb 7, 2019
    virginia
    I have a control valve that I like to reuse so can can back wash the tank a few times a week. What's making the tube stick to the control valve, when filling the tank with calcite. Will adding a little plumbing grease to the o ring in the lower control valve fix this problem?
  5. Bannerman
    Bannerman Well-Known Member
    Mar 19, 2014
    Ontario, Canada
    Silicone grease is to be used on all O rings when assembling components. Without lubrication, there is a potential of damaging or deforming the O ring with the square edge of the riser tube when reinstalling the control valve to the top of the tank.
    Suggest lubricating the top outer diameter of the riser tube to ensure whatever length of tube that passes through the O ring will be adequately lubed.
  6. Lizzard2
    Lizzard2 New Member
    Feb 7, 2019
    virginia
    Thanks, when I replaced the parts inside the control valve it came with silicone grease that's why I asked. Like
    Danco Plumbers Silicone Grease? I think I will keep my orginal tank and remove the media and just add calcite. Will I need to first add 20 lbs of gravel in the bottom? Should the tube only be 1/2" above the top of the tank?
  7. Reach4
    Sep 25, 2013
    Yes, but that is only 0.5 ounces. https://www.danco.com/product/0-5-oz-silicone-faucet-grease/
    I like Molykote 111 5.3 ounce (150 grams) tube for o-rings. It is on the stiffer side. A little goes a long way.
    Dow MOLYKOTE 7 Release Compound is a little less viscous, and might be the better match for this job.
    I think it is like 12 to 15... but I could be off.
    Most controllers (Fleck and Clack) want the PVC distributor pipe even with the top of the tank.
    I don't know if there is a gadget to keep the tube down as you remove the controller.
  8. Lizzard2
    Lizzard2 New Member
    Feb 7, 2019
    virginia
    Where can I find Dow MOLYKOTE 7 Release Compound?
  9. Lizzard2
    Lizzard2 New Member
    Feb 7, 2019
    virginia
    It says 16 lbs. of gravel is needed for my 10x 54 tank, not sure how much room that will tank.
  10. Bannerman
    Mar 19, 2014
    Ontario, Canada
    I don't know the riser tube requirements for your non-Fleck/Clack controller. As you mentioned cutting the riser tube previously, I expect it may now be too short when re-seated in the indent at the bottom of the tank.
    With adding lubricant to the top of the riser tube, I expect the riser tube will be less likely to raise or twist when removing the control valve next time.
    There only needs to be enough gravel height to cover the bottom distributor.
  11. Reach4
    Sep 25, 2013
  12. ditttohead
    Jan 9, 2012
    Ontario California
Similar Threads: need calcite
Water Softener Forum, Questions and Answers What is the need for gravel bed in downflow backwashing calcite tanks? Sep 12, 2018
Water Softener Forum, Questions and Answers Iron filter needed Tuesday at 12:30 PM
Water Softener Forum, Questions and Answers Softener, Help with test results - what do I need? Jan 18, 2019
Water Softener Forum, Questions and Answers Iron & Manganese, need help deciding on system Jan 16, 2019
Water Softener Forum, Questions and Answers Need operating manual Dec 16, 2018
