Jack-of-All-Trades
I have had a submersible pump on an artesian well. The pump burnt out and we have been running on just artesian power. We still have a good pressure tank etc. from the old system.
I was wanting to install an on demand pump for taking showers etc.
Would it be possible to tap into the line near the house with a T diverting water toward a pump and then back to the main line with another T. We would only turn on the breaker to the pump when we want more pressurized water.
Would we need to include a shut off in the main line - after the T for the pump inlet and before the T to the pump outlet - in order for it to work properly? Seems it would be less of a hassle if we could just flip the breaker and didn’t need to go outside to divert the water flow.
Would a simple ½ Hp shallow well pump work since the system is artesian?
Anything you think I would need other than the necessary piping, fittings, and the pump itself?
Thanks for your help.
