Adam Meyer
Hello,
I have an older Delta Faucet (model # 174) where the valve assembly has two threaded connections for the spout and side sprayer instead of the newer quick connection. I need to replace the side sprayer hose since it is leaking but I can only find it with a quick connect end which won't attach to my existing threaded connecter. Is there an adapter that converts a threaded connection to a quick connection or some other way to get the new sprayer hose (with quick connect) to work? I have attached a picture showing where I have threaded connections instead of the quick connect nipple just in case I'm not using the correct terminology .
Thanks.
Delta sells a spray hose with head assembly that comes with an adapter to connect to your threads and the new style quick connect.
Delta Rp31612 is the model number.
Thanks.
