Old Crane overflow cover & lever, how to remove?
Kenneth Thomas
Illinois
Cannot figure out how to remove this cover (to access / repair mechanism behind; drain is getting slower & slower, though far from critical).
The hole in the side of the lever seem to access where a lockscrew would be, but there does not appear to be a screw there-- it's just another round hole towards the center attachment, with no apparent head that could be turned. (Sorry, I tried but failed to get a focused picture of it -- could be rusted or possibly someone stripped it).
Thanks in advance for any suggestions.
DTAZ
Arizona
It's likely that the set screw for the handle was lost at some point and corrosion is holding the handle on. I would gently rock the handle (in and out toward the side of the tub) and see if there is any play. It may simply come off with a bit of persistent wiggling. If it's really seized on there you may need to resort to more aggressive measures.
Anna B.
N. Cali
Hi there. Did you ever figure out how to remove your Crane overflow plate? Mine looks identical to yours and we can't figure out how to get it off. It sounds like something is amiss inside and the tub isn't draining properly. Thank you
Ellen Trover
California
I am also trying to take one off & can't. I'm almost desperate enough to saw through the screw post.
Blurred Homeowner
portland, or
After seeing this thread and similar threads for the 1,000th time while trying to remove my Crane overflow plate, I thought I'd make an account and post the solution to the problem so that none of us have to go through this again.
The plate is screwed into the tub. It's similar to old Kohler overflow plates (which is where I found the solution). I used two screwdrivers on each side of the "grill" of the plate, pushed in through the holes to go behind the plate. This forms an "H". Then I turned counter-clockwise until the plate started to unscrew. After a little bit you can hand untighten. Beware that everything is connected to linkage up there, so you need to figure out how to get it completely off and out safely, but at least this will give you a start.
