I'm in the process of a remodel, and we just put up drywall. Plumbing, both main and inside, is all brand new (Uponor). Water meter is 1" Neptune T-10, digital readout.
I just started checking the water meter a few times a day to make sure everything was fine after drywall - and yikes, I show flow even though everything is off. I've been testing everything the past few days, and bottom line is I can't find a single leak. Moisture meter across every wall where pipes are located, nothing. The system is split up into 4 zones, and all will show anywhere from 1-7 gallons of water over a 12 hour period. Turning off all zones will cause the water meter to remain steady.
To further test, I shut off the main and internally raised the pressure of all zones to 80 psi with air, and it's holding steady after several hours, which seems to suggest there aren't any leaks in the system.
So why in the world would the water meter be incrementing!?
The water meter never shows any flow (with the digital arrow), it appears to be small changes or periodic fluctuations that add up to several gallons a day. I did see one time where it actually went *down* briefly, leading me to think there is some backsiphonage to the main.
There's no backflow device installed right now (no sprinklers connected). My only theory is that somehow the water is flowing back and forth across the meter due to the pressure changes (we're at the end of a small main, with around 30-40psi), and the meter is incrementing rather than just netting everything out. This only happens when zones are opened up, creating the back pressure as most of them are on the 2nd story, and thus creating illusion of a leak.
Obviously the next step is to install a backflow limiter and see if that stabilizes everything
I was just curious if anybody had any experience with meters and their accuracy. Hard to imagine the water meter is actually flawed, but I'm stumped otherwise.
