FatDaddy
My kitchen sinks and dishwasher and the slop sink in my laundry room drain into a drywell.
The pipe is 2" pvc and the run is fifty feet or more to the exterior where it leads to 4" (or more?) cast iron pipe going out to the dry well. The dry well is no longer accessible.
My issue is that even though I use liquid soaps and very rarely use the dishwasher, the 2" pipe clogs up with material that is almost like concrete. It takes over a year to get clogged. LUCKLIY there are low spots in the run and I can just cut/replace the pvc as needed when the clog gets too bad.
My question... does it make sense to install a couple of traps along the run to collect even more debris? I want as little as possible making its way to the dry well that is very old (fifty+ years?) as a failure would force me to divert to my septic system which might stress that and lead to failure.
Finally, are there pigs made for 2" pvc to help clean out the pipe? I have fairly easy access with a couple of cleanouts installed already. Cutting and replacing is easy too.
Thanks in advance.
Thanks in advance.
