Mark Holmes
I'm a first time poster, but I've benefited from advice in this forum many times. Thank you all for that.
I recently replaced my pressure booster pump with a much larger unit, and I'm seeing a high-frequency (4-5 times a second) fluctuation on the pressure gauge while the pump is running. The average pressure rises as I'd expect, but the needle vibrates between 3-5 psi above/below very quickly. When the pressure switch shuts off at 50psi, the needle spikes downward, causing the switch to turn on and off again very quickly—firing the motor for a split second. The pressure system seems to be working... but that rapid short cycle at shutoff seems really bad for the motor.
Some details on my current setup: see pic below
- 3000g storage tank, about 20 vertical feet above wellhouse; 1-1/4" PVC gravity line to pump suction
- New Goulds 25GBC20 booster pump
- 120g pressure tank, only 3 years old
- Square D adj. pressure switch, set to 30/50 -- also 3 years old, and was working fine with old pump
- New brass 1" swing check valve between pump outlet and tank T
I replaced the pump for two reasons: 1st because it's a requirement for my new house sprinkler system; and 2nd because while away the 3000g tank ran dry, causing the old pump to run and overheat.
I drained the pressure tank completely, reset pressure to 28psi, and it seemed to hold pressure fine. All the tests I can think of show that the tank is ok, and the diaphragm isn't ruptured. Some sediment definitely came down the line when the big tank ran dry, but I don't see how that could be affecting both the gauge and the switch, which are mounted on opposite sides of the T. Manufacturer indicated pump would prime automatically with positive pressure on the suction side, and that seemed fine. I pulled the prime plug to test, hence the puddle below the pump in the pic.
Help! Any advice would be appreciated. Air trapped somewhere? Pump not fully primed? Could sediment cause this? Something with the check valve? Seems like a simple setup, but I'm stumped.
Many thanks,
Mark
Many thanks,
Mark
