DIYER39
Terry,
Thanks for the posting.
I will probably redo the hot valve connection by sweating a stub on the valve and connecting it to the existing 1/2” copper with either a Sharkbite or copper compression coupling to eliminate the straig thread to tapered thread issue. . I’m not comfortable using a torch inside a wall due to fire potential.
If you had to choose, which coupling would you use inside a wall? Sharkbite or Compression? Soldering is not an option for me.
Jerry
Hey Jerry, assuming you are trying to follow "plumbing code", do they even make regular compression fittings for in wall use? If not that would make your choice a simple one but hopefully an expert can chime in and help.
Whenever I DIY electrical and plumbing stuff I always think about the potential for an insurance investigator to examine the work if something happens. Obviously Im no expert, but I try to follow the rules when possible
