NPT fitting doesn't quite fit in NPT tap!
BSPT (British Standard Pipe Tapered) is similar to NPT, but the specs are slightly different. Metric thread type is most common in Europe. It has a cylindrical inner and outer diameter precise in millimeters. The fine taper of metric tapered thread allows for the best possible force transmission. In writing, you can identify metric threads by a capital “M” plus an indication of their nominal outside diameter (ex. M22 x 1.5). Lastly, when measuring pitch size make sure you’re using a metric pitch gauge.
NPT thread type is most commonly used in North America. You’ll recognize it by its tapered outer and inner diameter which is self-sealing. When torqued the flanks of the threads compress against each other forming a leak-tight seal. However, it is still recommended to use PTFE tape or another sealant compound to guarantee a completely leak-tight seal.
A semi-compatible variant of NPT is NPTF (National Pipe Taper Fuel). It ensures an even more leak-free seal.
well I'm not reading through his posts again if the chrome don't fit but a gal or brass nipple does its bad parts he got ! Good luck diyorbust
