Odessa Eden
Hello,
Can someone chime in and tell me if NPT connection to water lines is the universal plumbing code to install a freestanding tub filler? I purchased a tub filler that has NPSM connections and my plumber says it does not meet Code and NPSM straight threads will not seal properly. The manufacturer says "NPSM is a common thread in plumbing applications. Connection to NPT without an adapter is possible with the appropriate amount of sealant and, in their expert opinion, it is sufficient for typical residential applications". Everything I read says you cannot connect the two and that and NPSM to NPT adapter would be needed for proper install in Massachusetts. Can someone provide any insight? thank you!
