armybuilder
Hello all,
First, thanks for taking the time to read and post. I recently had a new well drilled. It is 640' deep, 4gpm with 25' static level.
I'm wondering the best depth to put the pump. Several local installers have told me to put the pump at 400' in a balance between economy and water demand. It will be used for one 4 person household. Everyone I contacted recommended I use poly pipe.
Some recommended I use 250psi, but most said 200psi. One said put a check valve halfway. Another discrepancy was the pump. Most said 10gpm 1hp, another said 2hp 15 gpm.
Should I put the pump deeper on PVC?
Does this seem reasonable? I'm in North Carolina Thanks, Ben
