roundrightfarm
I'm installing a tub in a 3 wall alcove which will be tiled. The manufacturer says to shim under the concrete board so it overlaps the tub flange smoothly. This seems like a good bit of shimming, especially since one wall is full bathroom length. This wall also has a window which comes very close to the edge of the shower/tub tile. I'm worried that if I shim the entire wall, my window extension jambs will not quite fit. If I only shim around the tub, I see how the drywall could transition back to no shims smoothly enough, but I still might have an extension jamb problem at the side near the tub.
I could easily notch each stud on two walls and fit the tub flange flush with the stud edge. This would mean I would have to shim even more the one wall on the side with the spout and valve as well as shim a little less behind the flange on this wall. In this case, it looks like I may also need to shim behind the valve so it sticks out a little more to connect with the handle.
Has anyone done this before? Are there other problems I'm not thinking about. Thanks
