klaus8928
Hello. I have a Noritz NR71-SV tankless water heater with an RC-7651M remote. It was installed about 13 years ago and still works well, except for a loud noise it has started making (see link).
Unmute/turn up volume in the imgur and your device to hear the Loud Noise .
This noise generally occurs after a long period of idleness, such as first thing in the morning. It started about a year ago, is loud enough to be heard outside, and frequently wakes people up around 5:15 AM. The noise occurs regardless of whether a hot water fixture is opened slightly or fully. Typically, it only happens once and will not reoccur throughout the day.
I descale the unit every two years. Our local water is somewhat hard, but not severely so. After a one-hour flush, there is evidence of removed scale but no rust, and the buildup is nowhere near as extreme as examples I've seen online. The home does not have a whole-house water filter or softener, but there is a properly functioning main pressure regulator.
The linked audio was recorded about one foot away from the unit. Note that this issue never occurs when a cold water source is opened.
Finally getting after this, and Noritz is closed today so thought I try here. Thanks!
