Hillsteader
Hi, I'm new to this forum and to well systems. I live in a double wide trailer with a submersible well system ~100 ft deep. This year I began a total re-plumb with pex because a lot of the pipes burst last winter. I thought that was my main problem but recently the pump motor died, I think due to a malfunctioning well tank (pics). The tank (if that's what it is) is buried up to its lid under the house with the main water line coming out of it. It's definitely not pressurized and it's definitely not storing water. It seems like it's not doing anything except being gross and causing my pump to fail! I plan to install a whole new system with a new pressure tank inside the house. However, winter is coming and we don't have the means to do this for a while. What can I do to winterize the main line coming through the tank? Should I fill the tank with dirt or gravel? My plan is to just leave the tank in the ground and move on. Or is there something else I have to do to "uninstall" or "disconnect" it? Since I don't really understand how it is supposed to function, I'm not sure if I can just walk away from it. Thanks for any advice!
