girlinmiami
I just had a new well installed with a myers 1.5hp pump. The well is 2" pipe, with no foot valve. I placed a check valve by the pump but I seem to lose prime right after shutting it down. I know all the connections from the well to the pump are perfectly sealed. Since this is a new install I haven't done anything with the discharge side. I was wondering if I need to put any kind of seal on the discharge side to keep air from going into the pump and maybe causing the pump to lose prime, or is that not the case?
