Leetamus
Hi!
I'm worried my pump may have burned out and wonder how I would troubleshoot that?
The Scenario:
My well is around 130' deep, submersible pump. It feeds directly to a cistern which is fed back to the house and is controlled by a float in the cistern. We had a super cold spell this week and I noticed the cisterns were not filling up. The line connecting the well to the cistern is easy to check and seemed to be empty so I assume the well head was frozen. I could also hear the pump running even through no water. I turned off the pump at the breaker and set up a light at the well head to help keep it warm. As of last night the temperature has come back up a few degrees above freezing.
This morning I turned the pump back on and I can again hear it running, but no water... The pump was replaced last year and I REALLY hope it's not fried from running while the lines were frozen, not sure how long that was happening... I am blown away there's no safetey mechanism to kill the pump if the lines are blocked.. maybe there is.. Any suggestions on steps to try to get this thing working? Is my pump damaged?
EDIT: Wanted to add that when the well pump is running there is also a trickle of water coming out of some sort of overflow/pressure pipe at the top of the well. Yesterday when I tried the pump it was just a drop occasionally, today it's more of a very light stream.
The Scenario:
