No Toilet Flange on slab floor
Jake12
Utah
Had bath retiled. As shown in photo there is no flange. Bolts directly in slab.
I did replace the toilet a few years ago and used the double wax rings and didn’t have issues but wondering what the best way to handle this would be? It’s a 3”.
This may or may not solve your problem. I also used the double wax rings before - wrong solution. They will eventually shrink and you'll have sewer order/air leaks. This kit worked for me because we had an existing flange, but the tile had raised the level above the flange, i.e. flange extension. If you have screws to mount it the slab (or perhaps, can use concrete screws), I'd think that this would work to bring your flange up to it's proper level (maybe 1/4" above your finished flooring). There are different sizes available.
1/4 in. - 1-5/8 in. Toilet Flange Extender Kit​
There's other options out there. Look up "Toilet flange repair kit" on a hardware/box store website. Don't worry, it usually not that hard to fix. If you have a broken cast iron pipe in there, you'll have to do some more research, i.e. more complicated.
Oatey also makes this twist in thingy. I don't like 'em, but it might be your simplest solution. I prefer something mounted solid to whatever floor base there is.
You could just put a repair ring in to hold the closet bolts, but just use the wax to the floor.
