No heat bedroom/bathroom
Plumber69
Prince Rupert, British Columbia
Bedroom and bathroom share same zone. Bathroom is infloor heat bedroom is baseboard. I know this is wrong but Im sure the bathroom is air locked. Would shutting off all zones in house except bedroom/bathroom force air out? Theres new autovents on the supply and return
JohnCT
Still learning..slowly
Northeast
How is the hot water delivered? Is there a circulator involved?
John
JohnCT
Northeast
yes. She had heat before pump siezed and dumped water. I do get water out of both autovents if i push pin down. Heat works every where else
Is there a circ for each zone or is there one circ and zone valves?
If it's air bound, sometimes you get water before you get air. Make sure your water fill valve is working, and check boiler pressure as Fitter suggests. The pressure should stay up while you're bleeding.
John
