Sachin Soneji
Got the garbage disposal installed by plumber (never had one) and having problem with waste backing up into other sink as soon as garbage disposal is turned ON. Pic shows my setup. Plumber says my double sink are a problem and they are too low compared to wall drain outlet. Nothing can be done and the only way to fix would be to lower drain outlet which means redoing some of the cabinet
I don't think he is right. There should be some way to connect the pipes so that the waste flows to P-trap and not the other sink. If you look at my setup, when garbage disposal is turned on, the water rushes to other sink instead of dropping down to P-trap. Is it because once the waste water is out of the garbage disposal it has a very short run?
What could be a better way to connect the pipes?
