Richard Cropper
Hey guys, so I am having an issue with my furnace. Its not new but selling the house and it needs fixed. So when the unit is in heat mode, auto fan and door shut I get no blower. Take the door off and the blower comes on immediately. The fix I found was taking the switch out of the metal housing on the unit and letting it hang. Worked that way perfectly fine for the last 4 years. When you out the door on the bottom 1/4 of the door makes contact somewhere causing it to turn off. Any ideas? Thank you!
Nordyne M1GH 070A BW
*Edit: So I found the switch to be getting hit by the door centering the rocker switch and causing it to select neither the auto or on. Figured it might be the wrong switch so I check the model and fan switch. It is the right switch but it seems like it should have a plunger switch on it...
