Niagara Stealth problems
Discussion in 'Toilet Forum discussions' started by randy crocker, Sep 21, 2017.
  1. randy crocker
    randy crocker New Member
    Sep 21, 2017
    wildomar, ca. 92595
    I'am hav'ing a problem with this toilet running and the bowl draining after flush. This is a niagara stealth n7714 toilet. I've replaced the flush valve seal twice and thats not the problem. The tank seems to drain down about every 5 min. or so and I'll hear the tank refill for about 3 sec. Also after the flush is finished the water in the bowl will drain down to a low level sometimes leaving a little air gap. I've replaced the flush valve twice, even though it did'nt need it. I poured a bucket of water down the bowl which went down just fine. Niagara is sending me a gasket that goes from the tank to the unit in the tank( no idea what you call it) but have no idea of how to remove the unit from the tank. Any help would sure be appreciated, Thanks
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    A useful l troubleshooting method is to turn off the supply water to the toilet. Note how the water in the tank falls over time. The level at which the water stops dropping helps to identify the cause.
  4. randy crocker
    Sep 21, 2017
    wildomar, ca. 92595
    I've given this a try, the water level in the bowl dropped about 1" enough to create an air gap. The water level in the tank has dropped about 7" with about 1" of water left on the bottom. It seems to have stopped there from what I can tell.
    [​IMG]
    photo added by Terry
  5. Reach4
    Sep 25, 2013
    So that is the level I would be looking at.
    Looks complex. Possibly when the water has dropped to about 1/2 inch of where it is going to stop dropping, a few drops of food color into spots in the tank would show the flow.
    [​IMG]
  6. randy crocker
    Sep 21, 2017
    wildomar, ca. 92595
    ok, i will give that a try and see what happens. thanks
  7. JamesEspinosa
    JamesEspinosa New Member
    Sep 21, 2018
    California
    I have that same problem, did you ever figure it out? Thanks in advance!
  8. Jim Nichols
    Jim Nichols New Member
    Nov 13, 2018
    Washington
    I have the same problem, replaced flapper seal, still leaking down. What is the fix?
  9. Ben12345
    Ben12345 New Member
    Wednesday
    California
    Hey guys--- I had the same problem and contacted Niagara... the air transfer tube is clogged. Remove the tank and pour hot water down the small hole. Good luck! -Ben
Similar Threads: Niagara Stealth
Toilet Forum discussions Niagara Stealth, New efficient toilet rec? Nov 27, 2016
Toilet Forum discussions Niagara N7717 Stealth Toilet Review with Pictures and Comments Jan 11, 2013
Toilet Forum discussions Stealth toilet by Niagara, Niagra Jan 10, 2011
Toilet Forum discussions Niagara Flapper Closes Too Quickly - 1.6 GPF Toilet Mar 10, 2018
Toilet Forum discussions Replacing Niagara right side feeder Aug 24, 2016
