Ed Megarry
Hi All,
I bought and moved into my money-pit,, err um house in August 2016. Lots of issues all over the place, but since this is a water based community, I will limit my woes to that...
Lots of issues, iron, maganese, IRB, sulphur smell, and a bit of coloform... I bought and installed a filter system,, (2 big blue housings, 20 micron sediment and 5 micron prefilter, then into a hydrogen peroxide injection into a whole house backwashing carbon filter, and finally through a Silecte quantum disinfection unit)
woo-hoo, I have clean water,,, last piece was a RO unit under the sink,, and,,, no pressure for it to work at all.. nothing,, nada...
Took a look at my pressure switch its a 20/40 and the pressure tank is prob about 20 gal,, (36 inch high). It cycles for everything I do, every flush of the toilet, goes through 7 or 8 during a shower,,,
At first I was just going to add a booster pump for my RO, but my pressure sucks (and coming from the city that had 60psi steady pressure, and now 20psi in the shower I barely feel like I am getting wet).
I have a split level ranch, so all this stuff is squeezed into the half height part of the split stairwell in the middle of the house. I figure that is why such a small tank and low pressure switch was used, since to increase it, I would need to add tanks, I could probably squeeze 3 of them in the space at most)
I dont know too much about the pump except that 1/2 HP is written in sharpie on my pressure tank.
So, I could just get the booster pump for the RO, but for about 400 bucks I can get the complete CSV setup with tank etc. So.. question is...
Would a CSV be the best route for me to go to try and increase pressure and get the
RO working?
How probable that the well cannot provide the water needed to keep the valve flowing at 50 PSI?
If I put in the CSV, would adding a mesh spin-down sediment filter before the the CSV help keep it running better? or will that cause problems with the pressure?
Thank you everyone..
RO working?
