truckster
I'm new at this and new to wells, tanks and the like so I'm wondering if I could get some more info
Adding some garden irrigation caused my old well to run dry a few times.
Had a new well drilled to 420' with 4 gpm.
driller told me grundfos 3/4 HP 5 gpm pump but didnt specify model
He mentioned that by setting the pump at 350' I could use the wells capacity to irrigate the gardens and some birds.
Water level is at 12' in the casing from ground line so the pitless will be 7' above the water.
the bladder tank will be 280' from the well with just minor grade changes.
I was looking at Endot blue poly 1" at 200 or 250 psi
Can I get info on tank, pump, pipe please
